how the hell do i get this out?!?!?!
Old 02-11-2005, 11:26 PM
blind527's Avatar
Default how the hell do i get this out?!?!?!
one of the pcm bracket screws are STRIPED. i pulled back some of the plastic covering from the windshield and the ratchet extension fell through there and i don't have a magnet, nor can i see where it is. what the hell am i gonna do?
Old 02-11-2005, 11:43 PM
horist's Avatar
for the PCM bracket screw ... go to sears and buy a set of "easy outs"
for the ratchet extension ... go to sears and buy one of their magnet wands.... preferably w/a head that can change angles
best bet is to lift the car up, put jackstands under it and feel around ....
Probably nothing to worry about though... in 2002 I lost a 10mm socket ... in may 2004 I found it in a gully in the K-Member heh .... but if you dropped it up top.. it's on the bottom most likely .. so get it in the air and feel around....
Old 02-12-2005, 12:54 AM
blind527's Avatar
i had to break the plastic piece around the PCM to get it out, otherwise i had nothing to get it out with...is there a replacement part for this?
Old 02-12-2005, 01:08 AM
horist's Avatar
for the gray plastic pieces that cover the stock PCM??
if so... I'll check on the part numbers in the morning (I haven't had them since 2001)
(sorry about the edit... it's exactly what was posted... but if any problem PM me )
Old 02-12-2005, 01:12 AM
blind527's Avatar
the plastic thing that holds the PCM and is held with the 10mm bolts. where in IL you at? i used to live in algonquin
i also need to remove the screws that are still in there for the 10mm bolts cause i had to bend it. do i need a screw driver to pop the color coded wires open?
Old 02-12-2005, 01:37 AM
horist's Avatar
I'm round wauconda/island lake/lake zurich
edit: oh so you broke the PCM cradle thing? I'll try to find that part number too ....
I've had my PCM out at least 54 times ... worst I've ever experiences is a VERY scared/scratched up hand heh
Old 02-12-2005, 09:26 AM
blind527's Avatar
ha my x gf lives in wauconda
thanks for helpin me out man, appreciate it.
Old 02-12-2005, 12:20 PM
horist's Avatar
See Attachments... you want part number 4 based on your model year
Attached Thumbnails how the hell do i get this out?!?!?!-pcm_number.jpg   how the hell do i get this out?!?!?!-pcm_tray.jpg
Old 02-12-2005, 12:55 PM
blind527's Avatar
hey man thanks!!! the only confusion with the 1st attacthment...
i don't see a 97? i see a 98 and 99-02, which one would i use? i'll put that part number in and see how much it costs.
edit: i thought i put down i had a 97 when you asked me what year i had? for some reason the post didn't go through. instead of you doin the work, just link me to the site with the parts so i can try to check it out and you can tell me where to go
Old 02-12-2005, 01:26 PM
horist's Avatar
Ah ok, well luckily the part manual I have is for 93-02 F-Bodies
The manual I'm using is actualy a 640MB pdf file , so there aren't any URLs for it heh (There are some parts manuals online but I don't know any of the URLs off hand)
Looks like you need part 1
Old 02-12-2005, 10:36 PM
blind527's Avatar
thanks a ton dude, i ordered the part from gm direct $3.87!! thats it.
