2004 Corvette PIN assignments
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRY
48
CPP Switch Signal
I believe its #35
BLK/WHT
771
33
PPL
420
34
WHT
776
35
GRY
48
CPP Switch Signal
I believe its #35
Ok for under the LH side of the dash they list
(10) Clutch Pedal Start Switch
(11) Clutch Pedal Position Switch
but the CPP switch signal is the only one connected to the PCM, checked both blue and green connectors, which is #35 gray wire. You sure your counting correctly??
yes, otherwise just got right to the connector under the dash thats connected to the clutch. Its a two wire connector with one pink (hot/ignition) and one gray (cpp signal). The pedal start is part of the starter relay circuit and has nothing to do with the pcm. If you have a service manual the CPP switch your trying to connect to is considered part of the cruise control circuit.
