All-encompassing tuner???
Old 02-23-2005, 03:13 PM
99Hawk262's Avatar
Default All-encompassing tuner???
I've been looking through these posts for days and it has all become a jumble. Can anyone tell me if there is a tuning option that will do everything for me. Like adjust the automatic tranny parameters, delete A.I.R, EGR, rear O2's, torque managment, adjust engine parameters and anything else I could possibly want to do. I don't want to spend 1,000's of dollars. Is there something affordable to the average joe that will do all this? Thanks for any help even though this is probably a common question.
Old 02-23-2005, 03:23 PM
LS1 Sounds's Avatar
I plan on buying HP Tuners within the next week or two to meet all of those needs for me.
Old 02-23-2005, 04:44 PM
HumpinSS's Avatar
HPTuneres or EFILive
Old 02-23-2005, 05:40 PM
mrr23's Avatar
ok his question was is there one that will do everything for me. the closest would be predator and have someone burn you a program and upload it. second up would be the vinci handheld. while it does not delete items, it'll set the parameters far enough as not to trip the code. jwitt2 used it on his 99TA with longtubes, no EGR, no CATS, no AIR. never got the codes for them.
Old 02-23-2005, 08:55 PM
99Hawk262's Avatar
I know the Diablo will let me mess with the tranny and tune the engine, and I'm assuming it will let me delete or eliminate the AIR, EGR and O2's enough to not trip codes. Is this a correct assumption? Also, will it let me delete or tune the TM? Thanks for all the info.
Old 02-23-2005, 10:15 PM
Moderator
jimmyblue's Avatar
Predator will delete codes, but will not prevent them coming back.
Unless you get a custom tune done, which can be a bit of an
ordeal from what I've observed. Don't have any knowledge about
the Vinci handheld but you've got the man here, for that.
If you want to work on the vehicle yourself you want to own
the tool and the capability to program, not just the "bucket"
for somebody else's tuning work. But if you want it done for
you, a handheld is a more cost effective (depending on the
arrangement you have with your provider of tunes) way. In
the middle, you would have to weigh the pros, cons, expense
and your likely path.
With handhelds you will always be in that dependent mode,
while with the PC based software & cable you have more
personal capability, and responsibility for the work (and a
hundred or two fewer bucks in pocket).
The other thing that the handhelds don't really offer (that
I've seen, anyway, mrr23 can correct me) is the ability to
log vehicle operation, which I consider essential to "closing
the tuning loop", getting the data to interpret the vehicle
(mis)behavior and what it might be asking for. Real time
display is somewhat useful but a menace while driving, and
ephemeral. Predator only gives you a very limited set of
params to see and to touch, totally missing things that pertain
to more substantial mods (like VE table for heads/cam, and
so on). The Crane/Vinci at least appears to have a set of
some "common mods" tunes that have a chance of matching
your situation. But the more "individualized" your setup, the
more likely you want either full-on custom tune support (which
you would do well to understand and negotiate prior to purchase,
vendor is everything here) or you be the tuner, yourself, and
that means the PC based tools. Or you could hire it done but
a couple of times down that road, and you're past the cost of
ownership. Though knowledge, especially if it comes from
mistakes, has its own price.
Old 02-24-2005, 07:47 PM
mrr23's Avatar
well the VHP handheld doesn't do any datalogging. according to predator, it does live reading. doesn't log. here's right off their site.
The Predator will also include diagnostic features, such as the ability to read fault codes and erase them, as well as live data from your vehicle's sensors; this technology was also borrowed from our OBD-II tool, the Hellion.
