can someone with a 98 car go look quick..
at their pcm.
don't laugh and don't ask but i need someone to tell me which connector goes to which spot, long story short i'm having a massive problem and need to be sure the pcm is connected right to eliminate the possbility. my lettering where it tells you "red" and "blue" on the ports is not legible anymore and another long story short-they got put in wrong one time a few years ago and so the little plastic tabs that catch if you put them in wrong don't catch anymore..so mine will slide in either one the same at this point and the damn pcm itself slides into the plastic holder just as easy both sides,too so that's no help.
just use those bigger numbers on the top of the pcm across the top and bottom for reference to explain which side is which or something please.
need this ASAP if anyone with a 98 can go look for me, thanks.
