is mult. tuneing from different tuners bad?
I have had the stock tune, then Diablo (predator) tune installed, then installed cam and had it LS1 edit tuned but would like to tweek the tune a little, would HP tuners work, or am I asking for trouble using all these different tuners on the same pcm or will this not hurt at all? seems to me they are just diff. programs to edit no.'s in the pcm or am I wrong?
thanks for the help
thanks for the help
shouldn't cause a problem ... you download the current pcm flash file jfirst, then modify that... so once you make changes you'll be writing your changes and everything you didn't change back into the PCM
thanks for the help
thanks for the help
