Fuel Trims and Fixed Orifice PCV
I have noticed that my FTs are shooting up on decel, and I got to thinking it may be a vacuum leak. Then I remembered that I have the fixed orifice PCV installed. Could this be the culprit? I am going to put in a new PCV and check all my vacuum lines tomorrow. With my foot on the gas pedal FTs slightly negative, foot off FTs climb to the max, all at the same MAF frequency in Hz. Anybody else think this may be the culprit?
Moderator
PCV makeup air should be drawn from after the MAF and
sensed by MAP so I would not think it should matter to
either airflow method. But if you had the makeup air
unmetered then it might.
What about DFCO? Is that out of the picture? Dunno if
fuel cut happens on F-bodies. Can you see anything odd
in the injector pulsewidths, vs CylAir?
Well I just got done with my logs after capping off my PCV port. It looks to have made a big difference. All of the weird positive spikes are down by at least -10 STFTs, and a lot of my positive trims were getting dragged negative on average. I forgot to reset my trims, but I will do that later. From my logs it looks like the fixed orifice flows about .5 g/sec at idle. That's a pretty noticable difference. And my idle was smooth as silk, big difference there. I picked up another stock PCV ($6...seems a bit pricey to me). My old one (taken off many miles ago) does not appear to have been sealing properly anyways. Any thoughts about whether or not the PCV will shut completely at idle? I can seriously deal with the difference it is making. I may need to go back to my VE table to correct the rest of my positive trims (I think I overdid pulling fuel in the "decel" area). After that, all should be well. Sweet. Plus it looks like my MAF table is pretty close to dead-on.
Originally Posted by P Mack
Keep in mind, even if you're not getting unmetered air through the pcv, you may be getting unmetered fuel from crank case fumes that would change your ltrims.
If you are running the Fixed Orifice PCV and a cam, I recommend you remove the PCV and put in a stock one. It affects FTs, and idle quality a lot. I did a test run (54 miles) today, and cruise is much much better.
Stupid question: what is a fixed orifice pcv? If I haven't messed with my stock pcv i shouldn't have to worry about it right?
