Cold Cranking Issue/Tuning?
Old 03-18-2005, 09:40 AM
what a rush!
moregrip's Avatar
Default Cold Cranking Issue/Tuning?
My Radix'd 6.0 has developed a cold cranking issue. Once fired, it is fine.
It gets hung up on the cranking portion before firing, sometimes requires 2 bumps, this is only a cranking problem and only when cold, any ideas?
Old 03-18-2005, 10:05 AM
Moderator
jimmyblue's Avatar
There are some cranking enrichment terms in the fuel
tabs. I haven't played with them. Do you also have a
big cam with the blower? I suspect the cranking VE
may be pretty depressed if so, and maybe way over-
enriched at cranking?
Old 03-18-2005, 06:23 PM
what a rush!
moregrip's Avatar
my only mod is the Radix, no Cam or anything, it has the Stock MagnaCharger tune, is the cranking VE table the one I should be looking at?
There is a loud sucking noise, and some stumbling before it actually fires, that sounds rich to you?
