removing pcm??
removing pcm??
Im running my nitrous line and I need to get to the rubber groment under the pcm how does the pcm slid out and what size are the bolts , quick help please>
Pull pcm, unloosen the wire loom and clamps that attatch to the firewall. This will give you some slack on the harness that goes through the fire wall. Go inside and pull the harness and gromet inside all at one time. The gromet is secured to the harness. I then cut a clean hole in the gromet and reinstalled and secured loom on eng firewall side.
Helpfull hint before I renstalled gromet and harness I installed a section of the black conduit and routed it around pcm and left it for a open path and easy way to route any wires next time without removing the pcm.
Sorry miss read, remove bolts that hold plastic holder and unclip pcm from it, move it over and pull pcm out and the pull plastic case over,and out. It is all just held in by the 2 bolts 8mm or 10mm?.
