unbalanced ltrims
Thanks guys for the Ideas,this has been this way since I have been able to monitor it,
about 2 years. It has new denso o2's,Ive checked for leaks a couple times with no luck.I guess it could be a mismatched injector set since the are stock.I don't think it's
a mechanical valve train issue but I will be able to rule that out shortly as it's getting
a heads and cam update soon.Maybe I'll upgrade the injetors when I do the heads and cam to cover all bases.
are there any times during acceleration or deaccelration that they should be different becaue mine vary from time to time recently i put in rear corvette o2 sensors could they be causing the problem
