ses misfire after 30lb. injector swap???? help
My car has been sitting for over two months. I swapped my 26lb injectors for svo 30s during that time. I flashed the pcm using HP with the new injector control numbers and then started her up. I let her idle for 15mins. and I got a ses light (not blinking). HP showed misfires. #7 cyl. seemed to misfire the most.
misfire history from a very short log while at idle
cyl# misfire history
1 119
2 175
3 312
4 329
5 194
6 232
7 445
8 262
Car never had this issue before the injector change.
What should I look to solve this mystery?
1 119
2 175
3 312
4 329
5 194
6 232
7 445
8 262
Originally Posted by HumpinSS
did you desensitize the misfires after the cam swap. go back and push on all the injector connectors to make sure they are all seated
engine diagnostics---> misfires and set the low idle table to 32767 for the whole table
low rpm, idle(stopped), idle(moving)
