ABSINOP and ASR lights on after dyno
like i said above, i cant turn ASR on and my ABSINOP light is on.. Its been like 300 miles since i got dynoed, ive tried re-flashing the computer and it still didnt go away.. I reflashed it with HPTuners.. Ive disconnected the positive terminal of the battery a couple times for about 20 mins and it didnt work, i'm gunna let it sit all day. I posted this in camarov6.com and no one knew so they wanted me to post on here.. If you can help it would be greatly appreciated! Thanks
Happens all the time. It's on the drivers side, above & in front mid-span on the axle. You can reach it with a jack, no lift required. Look for a square connecter by the brake lines. It might be hanging loose, or just popped out a little.
i have the same ABS INOP and ASR OFF lights on my instrument panel but the car wont start and SECURITY light is on as well. any relation? i never had the car dynoed but im going to check and see if the cable came loose anyway. i checked the codes for the security light and i got the usual 12 and 55 code, but in addition to that i got a 31, 33, and 35. meaning short from courtesy lights to ground(31), short from courtesy lights to battery(33), and a security indicator light(35).
any help anyone?
any help anyone?
ya i think the resistor in the key isnt completing the circuit in the ignition key cylinder so im gonna tap into the line under the dash and put a resistor to simulate the key resistance... time to go buy an alarm.
car is on a jack, I looked on the driver side of the rear axle and i didnt find anything that would look like a plug except on top of the actual rear end transfer case.. can someone give me a diagram or a pic or something?
