A4 Transmission question
I had same problem, if you have HP Tuners or other check to see how much TPS reads at WOT, it may be reading low say 95% and your WOT downshift is set at 94%, and this closeness is causing the delay. That seemed to be the problem with my car, then when I reprogrammed I set WOT downshift to 90% and the problem has not come back. Although check fluid first becasue that is an easy fix.
