Best way to log AFR vs RPM vs MAP
Old 04-11-2005, 02:22 PM
SSkeet's Avatar
Default Best way to log AFR vs RPM vs MAP
I have HPT w/ enahanced IO and wideband.
When tuning VE (Mafless), what are the best ways to drive the car while logging values?
For example
-Should I just drive at all possible tps vs. rpm vs. gear vs. speed that I can possibly try to simulate, even WOT, for a while (20 mins?)?
-Or should I just drive around at part throttle in all gears?
-Or just log in one gear?
Old 04-11-2005, 02:33 PM
HumpinSS's Avatar
a little of everything. Try to hit as many ve cells as possible
Old 04-11-2005, 02:52 PM
LS1TECH Sponsor
foff667's Avatar
Old 04-11-2005, 06:05 PM
SSkeet's Avatar
Sounds good, thanks
