What sensor is this??? quick please
There is a sensor on the driver side of the intake manifold between the 2nd and 4th injector. It has two vacuum hoses connected to it along with a two pin connector. One Vacuum goes to the back of the intake the other is plugged off.
What is it? Can I disconnect it? Will it hurt anything?
AIR is off the car and should have been programmed out. Thanks
Ivan
Ivan
Ivan
Ivan
Originally Posted by dissonance
i think your speaking of the evap system... i think the car will run with out it but your going to get a code... at the least it needs to stay connected. one line goes to the fuel tank and the other goes to the intake... it pulls gas "gases" out of the fuel tank in to the intake.
