Injectors changed form 26 to 30, IFR table?
Old 04-15-2005, 07:29 AM
SlickVert's Avatar
Default Injectors changed form 26 to 30, IFR table?
I changed out the stock 99 injectors for SVO 30, how do I make the correct changes to the IFR table?
Old 04-15-2005, 08:56 AM
RedHardSupra's Avatar
multiply the IFR table by
(30*sqrt(58/43.5))/26.4= 1.312
how is your duty cycle at 6000rpm with your current setup? i'm getting 20-21ms@6000rpm with a dinky cam, so i'm wondering how a much bigger cam is doing.
Old 04-15-2005, 10:58 AM
SMOKINV8's Avatar
Keep in mind that your stock injectors are rated at 26lb @ 58psi.
SVO 30lb injectors are rated at 30lb @ 45psi.
Those SVO 30lb injectors in your car flow (IIRC) 36lb @ 58psi.
Old 04-15-2005, 11:29 AM
umm...no, please look at my math above, it's all in there
Old 04-15-2005, 04:36 PM
SlickVert's Avatar
RedHardSupra
I already switch out to the SVO 30, I never did checked the duty cycle.
Are you sure that all I need to do is multiply my IFR table by 1.312?
Thanks for your help Man
Old 04-15-2005, 10:37 PM
well, i'm about to do the same thing tommorow myself, and that's what i'm gonna be going by, so take it for what's it worth
