Doing 224 Cam This Weekend! Will....
Old 04-15-2005, 12:30 PM
~JOSHUA's Avatar
Default Doing 224 Cam This Weekend! Will....
I will have to wait for a month before I can buy the Crane Cams programmer. Is there any downside to changing the tables a month from now after my stock tune has gotten used to it for the time being? Any do's or don't about the tuning? Thanks for any advise!
Old 04-15-2005, 01:27 PM
Cal
Cal's Avatar
No, you'll be OK with a 224 cam. Just drill the TB bleed hole until you get a reliable idle.
Old 04-15-2005, 03:41 PM
~JOSHUA's Avatar
I don't want to drill the hole any bigger because I don't want things f@#$ed up when I get the Crane Cams tuner. I was asking about the spark tables and fuel maps being off after the "learning" during the maybe 200 miles before I get the program installed. I don't want to have a less than ideal re-program because the computer learning did something to the tables. Thanks for the input!
Old 04-16-2005, 12:51 AM
Predator's Avatar
Cal is right (as usual), you don't have to worry about that. You'll just be making the hole a tiny bit bigger, and it will help until you get a proper tune. The computer can't do anything to the tables.
Old 04-16-2005, 08:02 AM
apexman's Avatar
I doubt you will have to even drill the throtle body at all. I had a T1 on my Z28 and it was just fine doing nothing until I had it tuned. I also had a 225 and heads in my Vette at stock idle before tune and it was fine.
Good luck,
Derek
Old 04-16-2005, 01:21 PM
Rays C5's Avatar
Good luck,
Derek
I agree..... Maybe an idle relearn until you get some programming done. That cam is not that far off.... most have as d.d. good luck
Old 04-19-2005, 01:10 PM
~JOSHUA's Avatar
I finished the install and I LOVE the results. The idle stumbles a bit for a few seconds on a cold start, but no problem otherwise. I appreciate all the help!!! Thanks again.
