which power inverter for hp tuners
well i got hp tuners today and for some reason my lap top battery wont hold charge. so my question is what kind of power inverter have yall used and what kind should i get? the lap top uses a three prong plug.
thanks
shawn
thanks
shawn
Moderator
I use a little cig lighter 70W one from AutoZone.
It appears to have reacted badly to jumpy voltage
in a truck I was logging, and whacked my serial
port. I don't blame the inverter, it has been fine
for over a year in my car. But all of them have a
minimum line limit and if you're flickering around it
watch out. Might be best to first try refreshing
the laptop battery you've got, then try finding a
replacement that holds up.
Depends on the laptop. my 3.2ghz non centrino processor uses a ton of power and it'll overheat a 70 watt in no time. Most won't work on low voltage when the car is off. I've borrowed a friends 300 watt and it works perfect, never overheats or shuts off when the car is off.
haven't used it for hptuners, but i have a radio shack 140w for my computer. i use the laptop for my GPS, but hopefully HPTuners soon. i want a direct thing, hate going DC->AC->DC. i can fit all the power stuff under my passenger seat
