Question about positive LTFTs at WOT
Is there a specific set of qualifications that allows positive fuel trims at WOT? And is there some way to just eliminate positive trims in PE without forcing your trims negative?
Originally Posted by luv2spd
I've always thought that you'll get positive trims in pe if you had a positive ltrim right before entering pe mode. Usually happens in ftc 15.
I'm not entirely sure what the exact set of qualifications are. I've only gotten positive LTFT's during PE when my other LTFT's are significantly positive as well. What I've read about the subject seems to suggest that if the PCM has learned LTFT's that are significantly positive, it adds fuel during PE as a safety measure. The only way I know of to definitely stop it (aside from getting the rest of your trims in line) is to turn off LTFT's.
Positive trims at WOT is the computer saying hey I know we were this far off before WOT so I am gonna add this on top of the commanded PE value just to be safe. There is no o2 feedback from the computer to come up with this value. It just uses the last known value from the PT loop for WOT fueling if your trims are +
