How do I disable the MAF for SD tuning?
What all do I have to do to start logging my lrtims in SD tuning?
What kind of codes will I get and what do I need to do about them?
I have Edit, AutoTap and a Wide Band 02
Thanks
Thanks
Thanks
Thanks
just unplug your MAF, reset your trims, drive around for a bit to let the relearn, then start logging them. You will get up to 3 MAF codes, turn the SES light off if you feel the need but make sure the codes are still throwing. They bump you into SD mode.
Thanks
Thanks
the first post of this thread has a link to a word document
https://ls1tech.com/forums/pcm-diagnostics-tuning/284479-finally-how-tune-101-a.html
save that doc on the laptop you'll be tuning with... then read it until you have it memorized.... it tells ya what you need to know
