How to reset ltft w/ls1edit?
Old 04-29-2005, 07:05 PM
Rays C5's Avatar
Default How to reset ltft w/ls1edit?
As title says, how do i reset ltft with ls1 edit??? if not in ls1edit than atap??
Old 04-29-2005, 10:01 PM
horist's Avatar
I don't believe LS1 Edit or Atap support resetting LTRIMs ... I think that was an HP Tuners first? at least a first as far as tuner/scanner packages are concerned
Old 04-29-2005, 10:23 PM
Blacker's Avatar
I know LS1 Edit doesn't support that function. Just another reason why I traded in the LS1 Edit Cable for HP Tuners.
Old 04-29-2005, 11:18 PM
2xLS1's Avatar
Doesn't a PCM reset by pulling the fuses do it? Not as easy as clicking on a button in HPT, but still pretty easy.
Old 04-29-2005, 11:26 PM
horist's Avatar
^^^ yup, but then you also have to do the idle relearn , which gets tedious on cammed cars heh
Old 04-30-2005, 07:37 AM
Rays C5's Avatar
thanks for the replies!!! Pull fuses and go driving !!!!!BTW would they reset/learn after a long drive???
Old 04-30-2005, 03:09 PM
Blacker's Avatar
Yes they will. If you do not reset the LTrims, the new LTrims will average in with the old ones. That can take 100 miles to get an accurate LTrim. When you reset them, there is no averaging.
Old 05-01-2005, 04:13 PM
Rays C5's Avatar
thanks Blacker !!!!
Quick Reply: How to reset ltft w/ls1edit?
