ls1 383 tunning questions
i have mods liste din sig below and now im doing 383 and i nee dto know what needs to be changed in hp tuners for this set up any help is apreciated thanks yall
you'll need to change quite a few things...
One of the first you'll need to do is a crank re-learn. Set your IFR table, then work out your idle, VE Table, MAF table, Spark table....
A little searching will get you some good info on how to do it
Originally Posted by TAQuickness
What are you stuck with?
a 383 with a 224/224 cam? it will probubly idle and drive with a stock tune.....
really dude.......people "drive" around and are able to idle with 346s and a 224 on a stock tune........you shouldn't have to do much if anything with you extra CIs......
question:
why so small?
question:
why so small?
How do you tune a NA 383? The same way you tune any NA motor.
Once you have the correct cylinder volume size, and correct IFRs, go after the VE table which is a very popular topic on this forum right now.
Originally Posted by 2001CamaroGuy
why so small?
Originally Posted by ta_silver_bullet
are yuou talking about teh cam or the 383 too small. the cam i have had for awhile now and i dont have money to change it at this time. the 383 is all i have money for i got a good deal on it also. i had a valve tap a piston hard so i decided to go forged but i have a budget a tight one its just something to have for now sence teh car is broke and i got a good deal on it.
the cam.......as I said a 224 is mild in 346 engines (I had it in my car for a long time....REALLY GOOD cam but still small).....
I understand your idea of not having money to blow but something to keep in mind is that if you go with the 224 now and plan on putting something big in later, there is a chance that you "big cam" might not clear (might have needed larger piston notches) where as if you fork over the $ for the cam now, you can have the pistons notched and be finished before you put the engine in..........when I did my engine, I hit even with the 7cc valve reliefes that came in the pistons and had to add a good 0.150".......
just something to think about though........
