See this Dyno Sheet! Why does HP drop off at 5,200 RPM
Old 05-07-2005, 06:46 PM
Mark A. Rogalski's Avatar
Default See this Dyno Sheet! Why does HP drop off at 5,200 RPM
This is a 98 WS6. Crane 1.8 rockers, pushrods, etc. this week
Z06 cluth assembly and hydraulics this week
LT Jet Hots and a true dual exhaust system.
I was told "The car had a spark knock, even though you could not here it much, so we tuned it to get the knock out."
Any idea on what's going on here? The car seems to have steady power now..but less of it.
Old 05-07-2005, 09:41 PM
oange ss's Avatar
valve float
Old 05-07-2005, 10:17 PM
Texas Terminator's Avatar
what's your a/f?
Old 05-07-2005, 10:34 PM
WS6FirebirdTA00's Avatar
how many miles on the car, valve float could be a strong possibliity, or an improperly broken in clutch
Old 05-08-2005, 12:08 AM
32k miles
Old 05-08-2005, 12:20 AM
the high ratio rockers could be causing some valve float, valve float will look choppy kidna like what you have. whatn kinda springs u got?
Old 05-08-2005, 12:50 AM
Crane double springs for the Gold Race LS1 kit.
Old 05-08-2005, 12:57 AM
hmmm, i highly doubt its valve float with those springs
Old 05-08-2005, 01:16 AM
Blacker's Avatar
I am assuming a stock cam. In that case, they peak at 5200 rpm.
Old 05-08-2005, 01:32 AM
It is OEM cam. So even the all new Crane dual springs, tit reatiners, 1.8's rockers, pushrods, guid plates I am stuck with OEM performance numbers?
I can tell you this, when I picked up the car today I noticed in the first 4 blocks that it revs slower for sure. One other thing, in my garage when revving it up it backfires some. It has NEVER done that before. Aren't these signs of "excessive preload"?
Thanks for you help, really!
Old 05-08-2005, 09:49 AM
springs pressure could also be too high for the stock cam and lower power? i dont know just throwing ideas out. all i know is i can push my stock springs down to compress them and the duals wont budge.
Old 05-08-2005, 10:18 AM
Restricted User
EFI-101's Avatar
[QUOTE=Mark A. Rogalski]
{QUOTE]
Put some timing back in the thing and richen it up to get rid of the "spark knock" they were talking about. All the symptoms you are talking about lead me to think it doesn't have enough timing.
Also be sure to check the actual timing with a light against what the datalog says your getting. Could be off somehow??
Old 05-08-2005, 10:33 AM
yeah try to find out what your max timing is
Old 05-08-2005, 10:56 PM
7 Second Club
Phil99vette's Avatar
If you hook up a vacuum guage when doing a WOT pull, valve float will show as a bouncy needle. Normal conditions would go to almost 0 vacuum. Its a sure way to see if its valve float.
Phil
