few screen caps of my SD logging
Old 05-16-2005, 08:28 PM
seadoo's Avatar
Default few screen caps of my SD logging
hey are the logs that i got from logging the car, any imput would be great. thanks
Attached Thumbnails few screen caps of my SD logging-advance-01.jpg   few screen caps of my SD logging-air-fuel.jpg   few screen caps of my SD logging-lt-ft-01.jpg   few screen caps of my SD logging-retard-01.jpg   few screen caps of my SD logging-st-ft-01.jpg
Old 05-16-2005, 11:52 PM
txhorns281's Avatar
pretty colors...
input: running a bit lean at high load
Old 05-17-2005, 12:00 AM
405HP_Z06's Avatar
It looks like you need to do a 'right click' > Copy on the LTFT histogram and a 'right click' > Paste Special > Multiply by % - Half to your VE table. Reset fuel trims, log and repeat adjustments until FT's are +/-5.
Old 05-17-2005, 10:30 AM
horist's Avatar
looks pretty good... may be a little lean at WOT but hard to tell since it's narrowband... richen up the high load cells and you should be gold
Old 05-17-2005, 07:20 PM
seadoo's Avatar
wow, umm i wish i knew what you ment by that care to explain alittle. thanks
EDIT: i think i understand you, but still alittle more indepth would help
Old 05-17-2005, 09:26 PM
seadoo's Avatar
this is a cap of the new VE table....not too bad
Old 05-17-2005, 09:57 PM
WS6FirebirdTA00's Avatar
throw the ltft and stft numbers in an excel file and get a new ve table, looks like u hae a good bit of numbers to work off of, i would imagine that knock would go away once u give it proper fueling
Old 05-20-2005, 07:08 PM
seadoo's Avatar
well al seems to be well, car is running great now, im going to give it a few days before i relog it so it has time to relearn the fuel trims, ect. thanks for the info
