TPS problem.
Old 05-17-2005, 04:10 PM
Y2K SS's Avatar
Default TPS problem.
Just did a log and HORIST (as usual) noticed that my TPS was only opening 70%. Well I found out I had a vacuum line stopping it from opening it. No problem just moved it. I then with the engine off scanned and mashed the throttle. It opened to 100%...cool. But when I started the car and drove it only went up to 80%. Stopped the car and just turned the ignition to the ON position mashed it again and went back to 100%. Anyone know whats up with that??
Old 05-17-2005, 08:45 PM
99whitews6's Avatar
Have you raised the Idle set screw on the throttle body? Any TPS codes?
Old 05-17-2005, 10:16 PM
Y2K SS's Avatar
No TPS codes... car idles fine. What does raising the idle set screw do???
thanks
Old 05-17-2005, 10:19 PM
2000WS6Vert's Avatar
Did you remember to put the coversheet on the TPS report? (Office Space)
Sorry....I just couldn't resist.
Old 05-18-2005, 01:21 AM
Y2K SS's Avatar
Hmmmmm.. I must have missed something.
Old 05-18-2005, 01:32 AM
horist's Avatar
you MUST go to the local rental store and rent "Office Space"
I will not help you further until you do so or until you send me the updated TPS report ... oh and ... you red stapler... I want it back
Old 05-18-2005, 11:24 AM
Y2K SS's Avatar
You retard. I'll give you a red stapler alright. Anyway guys had cut some floor mats and crap also. I didn't think it was touching or didnt affect it but I guess it did.
Old 06-17-2005, 09:40 PM
CamTom12's Avatar
So what was the end-state? I've got the same problem - only 80 to 85% TPS at WOT as per my HPTuners log file (which I can upload)...
How'd you fix it?
Old 06-18-2005, 12:15 AM
CamTom12's Avatar
ok, I went out and checked the physical travel of the throttle and it's only opening about 85%. This would explain a whole lot...
Is there any way to adjust this? It's about 15 to 20% of the way from hitting the bump-stop on the throttle-body itself so I think grinding that would be somewhat useless at this point.
How do you adjust the throttle cable?
Old 06-18-2005, 03:17 AM
Drew778's Avatar
You don't need no stinken floor mats, thats just more weight
Old 06-18-2005, 05:02 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
Certainly wouldn't be the first time a floor mat kept the pedal from hitting the metal.
