few questions when tuning for a cam
ok well the table is looking pretty rich towards the upper left corner and then starts to lean out going down and over. ive started to make some adjustments to the ve up to about 4k, havent had the motor turning much higher. ive got the proportional idle turned off and thats it because that was being a bitch before to me.
i dont want to run into any troubles wot, is there anything i should do before a wot run to be safe or should it be ok to do it. ive got the timing backed off to about 26* as well.
