Will Bad Gas make my LTFT's go Positive?
Well I am in the works of a VE Tune had the LTFT's close to where I want them.But Then I had to get gas,Drove home all was fine.Then I had to go out and pick up a pizza,My Car didnt want to Idle,Surging and I noticed my Trims went from being -1 to-3 across my map board to Positive 4's5'sand 7's I was like WTF!I put dry gas in it when I got home.Drove it to work and Idle isnt as bad.But my Trims still arent right.Will bad gas mmake LTFT's go from Neg To Positive?Thanks!
Scott
Scott
Originally Posted by slow
changes in fuel will have an effect on the trims.
I started tuning a 42x ls1 motor with 6 month old gas in the tank, when we filled up during the tuning process, the trims were 10-20% off.
Ryan
Ryan
Originally Posted by 405HP_Z06
Your FT's will skew for a short time immediately after filling your tank. I surmise it's because of the fuel vapor system.
He is correct...you might want to do a search on the HPtuners site. We had a pretty lengthy discussion about Trims being swayed after a fill up.
