AFR at idle and part throttle? Good or bad?
Old 06-02-2005, 09:22 AM
ViciousVette's Avatar
Default AFR at idle and part throttle? Good or bad?
I noticed my AFR bounces from 14.7 to 16.x at idle, is this normal? or am I running too lean? While cruising, it goes into the upper 15.x range down to 14.7. (part throttle) Should I be concerned with these numbers?
Please note: This is my first week with a WB (LM1 w/ LMA-2 kit) and new to tuning. I just got my copy of LS1-Edit about a week ago.
Old 06-02-2005, 10:56 AM
SSpdDmon's Avatar
As far as I know, you want to tune those lean points out. Check the stickies in the forum regarding VE tuning and the MAF calibration files. That should help you clean most of that up.
Old 06-02-2005, 12:26 PM
Thanks. I'll checkout the stickies on the forum. So this isn't normal, right?
The reason I ask is because someone I know who's familiar with tuning says it's perfectly normal and it could sometimes reach an AFR of 17.x at idle. He's telling me not worry about it, but I find that a little hard to believe. I have a Vararam CAI and read somewhere on here that it tends to create lean conditions.
How high should my AFR max out at idle?
Old 06-02-2005, 12:39 PM
Nickn20's Avatar
tell us about the wideband setup? is this a bung in the header or tail pipe readings?
Old 06-02-2005, 01:16 PM
It's an Innovate LM-1 with RPM converter LMA-2. The WB sensor is located on the rear passenger side bung (no cats) which shouldn't affect AFR readings. (Kook's LT w/ X-pipe) It's not the tail pipe kit.
Old 06-02-2005, 11:46 PM
plumbr's Avatar
Mine idles at 15.0-16.0 afr, cruise is 14.5- 14.75 or so. What are your ltfts doing?
Quick Reply: AFR at idle and part throttle? Good or bad?
