Injector Scaling Ques.
Old 06-02-2005, 11:43 PM
2xLS1's Avatar
Default Injector Scaling Ques.
Are the Minimum Injector PW and Default Injector PW tables changed when scaling for larger injectors or is the Flow Rate vs KPA the only table you scale. I'm working on a car tuned by a Pro tuner who set the Flow Rate vs KPA for 42 lb injs when the car actually has 38s and he has those 2 tables way different. The stock/28.8 lb tables are both set with 1.277 values and the Pro tuner's file is set with .547 values.
Old 06-03-2005, 10:09 AM
2xLS1's Avatar
tttop
Old 06-03-2005, 10:12 AM
txhorns281's Avatar
IFRs should be the only thing you need to mess with
Old 06-03-2005, 10:14 AM
2xLS1's Avatar
Thanks, I'll set the 2 other tables back to 1.277.
Old 06-04-2005, 02:48 AM
soundengineer's Avatar
heres a link to a worksheet to help you put in the right values in teh table...
www.audiohelix.com/hptuners/injectors.xls
Old 06-04-2005, 11:04 AM
2xLS1's Avatar
I already have that and know how to scale them for the IFR vs KPA. It's the other 2 tables I was concerned about.
