FAST-Can someone take a look...
Hey guys,
I was wondering if someone can take a look at a couple data logs and whole files and see what you guys think.
The setup is:
502 BBC
1000cfm TB
FAST b2b w/ WB
40lb/hr injectors
48psi fuel pressure
I also have a NX plate kit. That's where I'm getting stumped. The air/fuel is going WAY rich w/ the nitrous.
Thanks.
Lee
The setup is:
502 BBC
1000cfm TB
FAST b2b w/ WB
40lb/hr injectors
48psi fuel pressure
Thanks.
Lee
Originally Posted by foxspy
Hey guys,
The setup is:
502 BBC
1000cfm TB
FAST b2b w/ WB
40lb/hr injectors
48psi fuel pressure
Thanks.
Lee
The setup is:
502 BBC
1000cfm TB
FAST b2b w/ WB
40lb/hr injectors
48psi fuel pressure
Thanks.
Lee
Lee send me your GCT and LOG files and I'll take a look.
brian@brianmacy.com
I heard that people have gotten false a/f ratios from the FAST while using nitrous. One guy's FAST said it was pig rich like mine, so he kept leaning it out until the FAST said it was okay, but actually was WAY lean and toasted his motor.
I get to 82% duty cycle w/ the 40lb/hr injectors.
I didn't check the plugs right after the run, they looked fine after 7 miles of running after the nitrous pass.
Suspended Sponsor
Could be a dumb question but what plate are you using? If for some reason it is a plate designed for a carb, then it could be simply because you have far too much fuel pressure for the way the plate/jetting is designed. The carb style systems are meant for no more than about 6 psi. Just a possibility I have seen it before.
-Bryan
-Bryan
-Bryan
-Bryan
