throttle cracker and follower, nothing about it in the help file??
Old 06-05-2005, 05:55 PM
WS6FirebirdTA00's Avatar
Default throttle cracker and follower, nothing about it in the help file??
so what do they do exactly? im not really understanding and before i change things i would like to know what they do. looked inthe help file and no results found. thanks
Old 06-05-2005, 05:57 PM
ok never mind, i closed out and reopened and it worked, hp tuners has been screwy.
anyway if someone can explain a little better and why you would adjust one for what and the other for what, i woudl really like that lol
Old 06-05-2005, 06:06 PM
P Mack's Avatar
I think the main purpose of throttle cracker is to hold your rpms higher so when you shift it is smoother. I think the throttle follower is mainly there for driveability so the throttle isn't so touchy, mainly when the throttle is snapped shut suddenly. I zeroed both tables out and I think I like it better cause the rpms come down fast and I don't have to wait between shifts.
Old 06-05-2005, 10:14 PM
so which table has to deal with that "cruise control" feeling when going down the road? or is it both? and how do the numbers work out, like what do they mean? i understand the decay table. is the cracker just the amount of iac steps it reduces in 12 ms?
Old 06-05-2005, 10:20 PM
Texas Terminator's Avatar
follower..........
Old 06-05-2005, 10:31 PM
thanks, and i want go to down with that right?
Old 06-05-2005, 10:44 PM
P Mack's Avatar
If you get cruise control until you come to a complete stop it is throttle cracker. If the rpms hang for a few seconds regardless of speed it's throttle follower. Throttle cracker is in units of massflow (g/s). I think throttle follower delay is in massflow per time (g/s^2) and decay is in seconds. And yes you want to reduce the values to get rid of hanging idle. Mine are all zero.
Old 06-06-2005, 02:28 AM
MNR-0's Avatar
Originally Posted by Texas Terminator
follower..........
Ummm... Sorry. Its Cracker. Follower is only used for idle close transitions. If ti cruises without cruise control on, then its Cracker.
Old 06-06-2005, 03:09 AM
Black02SS's Avatar
From personally tuning several cars, I have found that if the Running Airflow and VE were in line, then neither Cracker/Follower needed to be adjusted. I have yet to adjust these on any car I have tuned and all are H/C setups. JMO
Old 06-06-2005, 04:53 AM
yeah my ve is a little off, it wasnt doing this before, im trying that first. i believe it should fall in line after that. thanks guys
Quick Reply: throttle cracker and follower, nothing about it in the help file??
