Will MAF Frequecy change my A/F Ratio For WOT?
Originally Posted by Pro Mouse
I have to change my MAF table will this screw my WOT tune?Thanks guys
Scott
Scott
If you get your MAF dialed in correctly, you should be able to tweak it on the dyno using their wideband. That's what I'm going to do next time. I wanted a dyno baseline with a solid VE/MAF calibration. I saw KR at WOT and decided not to adjust anything. I've gotten rid of the false KR, now it's time to go back and adjust PE table and advance for max power.
Why don't you calibrate the MAF and take it for a nice run/scan? You can always look at the narrowband as a rough guideline. That'll get you an idea, and if you get KR you'll know it's lean--or false like it was with me.
