p0106 map values, engine diagnostics
I was getting p0106 and replaced the sensor only to come to the realization that it just the head cam setup I have putting the values out of whack and setting the code. So what I did was to add 20 % to the max and reduced 20% from the min map values under engine-diagnostics. So far hasnt set the code, I know alot of people just diasable the code.
my question is are these tables used to figure anything else other than just a check to makes sure map values are stock and a vacuum leak isnt present.
