SES Light Code 1133 MAF sensor?
Old 06-17-2005, 08:24 AM
Swedez28's Avatar
Default SES Light Code 1133 MAF sensor?
Went to Auto Zone they scanned it and got this code. Said I need a new MAF sensor. $125.00. My question is has anyone had to change theirs and is it a touchy thing to do or not? Any help will be great! Thanks!
Old 06-17-2005, 11:23 AM
calongo_SS's Avatar
It's easy to change, but I'd try cleaning it before you buy a new one. Get some q-tips and alcohol and GENTLY clean the sensor. I think some people have used an electronics parts spray cleaner with good results also.
Old 08-10-2005, 09:29 PM
Jake19_2's Avatar
Did cleaning or replacing the maf fix the problem?
Old 08-11-2005, 08:35 AM
Swedez28's Avatar
Yes it did work! Here is what I did, I took off the MAF from the throttle body, took a Q-tip and bent the end at a 90 deg angle, soaked it in some alcohol and gently just touched it to the front of the sensors. Just did it a couple times and replaced the MAF and it was fine. No problems since!
