HP Tuners logging problem...
A quick question about logging. When i add a new thing to log and click refresh it doesnt read the info from the pcm. i must be doing somthing wrong?
if i select default.config then open the chart display then select chart settings and then select chart 1 and add maf Hz to chart 1 hit refresh chart then connect to the car and log it shows all 0's for maf hz
am i doing somthing wrong?
Thanks
Thanks
