Stays in closed loop at WOT
1 Post
Got a car that won't go to open loop at WOT. It is in open loop when cold, then goes to closed loop when it should. Stays in closed loop after that.
I have checked everything I can find to check. Any ideas??
1 Post
Originally Posted by HumpinSS
22 is open loop what makes you think it isnt transitioning from closed loop to open loop. this is Dirk bret
1 Post
did you log commanded AFR by chance? GM.AFR_1
Edit - Nope, didn't get that one.
It will help closed loop will allways be 14.7 and when the car transitions to open loop you will see the Commanded AFR change ususally 14.7/PE multiplier will give you what the commanded AFR is supposed to be.... Can you send me the log
1 Post
