what effect does the IAT have on the engine performance
Originally Posted by brandonppr
what effect does the IAT have on the engine?
when the IAT temp goes up what does this tell the computer and viseversa
how does it use the IAT?
Originally Posted by SSpdDmon
...pre-ignition as temps rise (aka detonation)...
There is a chart in Edit: IAT vs load timing. It pulls timing depending on temperature and MAP.
To my opinion very useful for superchargers application when the charge cooler doesn't work fine.
I wouldn't remove this safety, in fact I see a lot of KR when the air is too hot and I set a too low timing reduction.
In my opinion it's better to optimize the intake (functional Ram Air or so).
Originally Posted by TAQuickness
Not to get to particular, but pre-ignition and detonation are two very different things. There is an excelent thread on this board describing the physical differences. I'll see if I can dig up.
Originally Posted by Engine Basics: Detonation and Pre-Ignition
Detonation
Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug.
Pre-ignition
Pre-ignition is defined as the ignition of the mixture prior to the spark plug firing. Anytime something causes the mixture in the chamber to ignite prior to the spark plug event it is classified as pre-ignition. The two are completely different and abnormal phenomenon.
http://www.streetrodstuff.com/Articl...ion/Page_2.php
Pre-ignition
