Under what conditions does the A/C get turned off?
I know the A/C shuts off under high throttle, can someone tell me all the conditions where this will occur, does the A/C get shut off due to RPM limitations as well?
If the preset RPM or TPS% is exceeded, the A/C clutch will be diabled. It will re-enable at a preset, and lower, RPM or TPS%. Only one needs to be exceeded for this to happen.
I had looked up the spec for similar Delphi compressor and its rated RPM was 6500 and with the pulley ratios that engine RPM makes sense.
The TPS settings seem impossible, on these cars can the throttle actually get to 100%? If I stomped the pedal on the floor at low RPM the A/C would never come on again, or would being below the RPM limit reactivate it?
You really do not want the A/C enabled while at 100% TPS, yes these cars will reach 100% when you mash the throttle. The reason the A/C disengages is not only to save the compressor, but to limit the un-necessary stress on the engine. Once the TPS% reaches the level you selected, like mine is set to:
A/C enable RPM: 3000
A/C disable RPM: 4000
A/C enable TPS%: 20%
A/C disable TPS%: 70%
Then the ECM re-engages the A/C clutch. The image posted is not the normal settings, those have been modified. The reason I have these settings on my truck is because I tow with it. My SS has similar values to allow the engine to put more power to the ground without being dragged down by the A/C compressor.
Moderator
I don't like the 100%/0% settings even though my
car will hit both. That means (like on a highway trip)
if you pass somebody once you won't have A/C again
unless you drop out of cruise and release the pedal. I
set mine to 4000/3800 for RPM and 70%/50% TPS
(Edit>System>A/C for HPTuners users).
Originally Posted by 2xLS1
The image posted is straight from a stock 02 M6 F-body file.
I tune so I have more stock files than I care to count. All 99-02 A4 and M6 F-body files are set like the pic I posted from the factory. 98s M6s are set RE/D - 3650/4000 - 81%/86% and 98 A4s are RE/D - 3950/4294 - 100%/100%. Vettes are even different from those. The settings I posted were used on such a wide span of years and tranny types is why I chose to post those and why I called them typical.
Not on our 1998 Z28, 2001 SS, 1999 Sierra and 2002 Silverado ... all factory bin files. As well as other factory auto bin files I have. I would just say this, GM set them differently on similar cars.
