LS1Edit any way to convert A4 PCM to M6???
Old 07-14-2005, 05:39 PM
FirstGen's Avatar
Default LS1Edit any way to convert A4 PCM to M6???
I have a 2001 PCM I used in my hybrid 6.0 with T56 swap. The PCM was for a 4L60E tranny and I keep throwing all these automatic codes that I have tried to delete. Can anyone tell me exactly how to change the PCM to a M6? I head something about changing the Segment Id numbers but I have tried all that with no luck? Any other ideas?
Thanks in advance!
Old 07-14-2005, 11:20 PM
FirstGen's Avatar
come on guys I know one of you have done this!!!
Old 07-15-2005, 12:18 AM
SmokingWS6's Avatar
see if you can find somebody to load in a stock m6 file for you with HP Tuners, change the vin to match the vin your ls1 edit is registered to
Old 07-15-2005, 10:29 AM
FirstGen's Avatar
Is there no other way? I have all kinds of tables changed on my file so would I have to go back and manually change all of those too?
Thanks for the help.
Old 07-15-2005, 01:33 PM
Texas Shadow's Avatar
Call Al . He did it for me.
Old 07-16-2005, 02:33 PM
wait4me's Avatar
Send me your ls1 file, ill send you the same file back up set up as an m6 in the calibration via hex. so you will just have to reload in your file and your done. jessebubb@yahoo.com I do this for free.
