po172, and po175....
Old 07-17-2005, 01:35 PM
natronathon's Avatar
Default po172, and po175....
could this be caused by bad spark plugs? I also know my maf has been reading low, but i had the maf tables readjusted to bring the readings more into line. Any suggestions?
Old 07-17-2005, 02:43 PM
DanaliHD's Avatar
i've asked this question before and gotten no good answer. i'm thowing the same 2 codes right now. hopefully someone will have an answer
Old 07-17-2005, 03:06 PM
10 Second Fun Car
jlrz28's Avatar
got the code also, 20-30 miles after removing the screen out of the MAF
Old 07-17-2005, 03:57 PM
SUPRYZE's Avatar
P0172 and P0175 are fuel trims rich, banks 1 & 2. Spark plugs won't do that.
If you know your MAF is reading low or is modified in any way, then the MAF needs to be re-calibrated.
Old 07-17-2005, 07:05 PM
i know the maf was origionally reading low, but i had a knowledgeable tuner help me get it much closer than it was previously, yet it never threw a code before, only after... i cleared the codes, maybe they will stay gone...
can the problem be fixed with VE tuning?
Quick Reply: po172, and po175....
