Maf ???
Old 07-21-2005, 06:48 AM
SSoofast's Avatar
Default Maf ???
If you decrease values in MAF calibration table does this lean it out?
Old 07-21-2005, 07:46 AM
Holden LS1 Tonner's Avatar
yes
e.g mine at 1500 hz is 2.14 g/sec , if i lower the number to 2.12 g/sec it will read that it is getting less air at 1500 hz and inject less fuel .
SSpdDmon's Avatar
Yes. MAFS = Mass Air Flow Sensor. If a smaller amount of air is being reported entering the motor, a smaller amount of fuel is calculated. The VE table needs to be close to what the MAF reports as sometimes it is a combination of the VE and MAF that is used for fuel calculations.
