injector questions
Old 07-21-2005, 02:00 PM
02sierraz71_5.3's Avatar
Default injector questions
Just put in larger injectors the stock ifr table was a constant value across the whole table. This is an 02 gm truck with a vacuume reference on the rails. every calculator I can find uses scaled ifr Im looking for a constant number
for
Injector Rated Fuel Pressure: 43.5
Your Fuel Rail Pressure: 58
Injector Rated Flow Rate 30
what is the formula
thanks
Old 07-21-2005, 08:37 PM
slowta99's Avatar
i found this link somewhere, I think this is what your talking about, credit to whoever made this table
http://www.transamws6.net/HPTuners/injectors.xls
Old 07-22-2005, 12:36 PM
thanks but those are scaled values I need to know injector flow at 58 psi
could it be as simple as (43.5/30)=(58/x)
Old 07-22-2005, 12:52 PM
2xLS1's Avatar
Yep, that simple. I would also like to know why GM used a fixed value on the trucks and scaled on the cars.
Old 07-22-2005, 02:17 PM
I think its because the have a vacuume reference on the rails, do they do that on the fbodies? Thats a good question I would like to know also I think it has something to do with a difference in the return system
Old 07-27-2005, 10:52 PM
what is the formula to figure how much and injector will flow at a higher psi, having some doubts on my math
Old 07-27-2005, 11:17 PM
2xLS1's Avatar
(43.5/30)=(58/x) will work. Just cross multiply and solve for x.
43.5 * x = 30 * 58
43.5 * x = 1740
43.5 * x /43.5 = 1740 / 43.5
x = 40
Old 07-27-2005, 11:56 PM
slow's Avatar
a static rail pressure has emissions benefits, which is why the cars went to them, but the trucks do not, as they are in a different class for testing. note; not talking about tailpipe emmisions, but the real testing that car companies have to deal with.
Ryan
