HPT A4 Shift question with 3:73 Gears ,Rpm=Mph? - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 07-21-2005, 05:48 PM   #1
Pro Mouse's Avatar
Question HPT A4 Shift question with 3:73 Gears ,Rpm=Mph?
Does anyone know what RPMs = MPH in 1st ,2nd and 3rd gear?
I think this is it if I remember right.
1st gear=149 rpm = 1mph
2nd gear=89 rpm = 1mph
3rd gear= 54 rpm = 1mph
Thanks!
Scott
Pro Mouse is offline   Reply With Quote
Old 07-21-2005, 05:57 PM   #2
horist's Avatar
depends on your rear tire but I'm getting
1st = 149RPM/MPH
2nd=79RPM/MPH
3rd = 49RPM/MPH
I just used the gear calculator on f-body.org (http://www.f-body.org/gears/) and divided appropriately
This was w/the 25.66" diameter rear tear
Keep in mind though you can't go by this w/an A4 w/a bigger aftermarket converter... the converter slips so you're never getting 100% of your RPM as useable (unless you lock the converter)
When I adjust my WOT tables I prefer to just use the RPM tables... I set the MPH real low for WOT shifts, but set the RPM to whatever I want it to shift at minus about 150 RPM
horist is offline   Reply With Quote
Old 07-21-2005, 06:14 PM   #3
Pro Mouse's Avatar
Thanks Horist.I have stock Tire Dia. P275/40 R17 Nitto Drag Radials Is that 25.625?I cant remember???
Scott
Old 07-21-2005, 06:22 PM   #4
Pro Mouse's Avatar
Horist Thanks for the link ,but is this right?I had to use a 98 f body A4
1st =3.06
2nd =1.62
3rd=1.00
4th=.7
???? I thought 4th was .6????
Old 07-21-2005, 06:23 PM   #5
Pro Mouse's Avatar
Oh Crap I forgot to add Does a Stall Converter Change this?
Thanks!
Scott
Old 07-22-2005, 09:54 AM   #6
YES! In fact if you log your Engine Rpm (SAE) and you Trans Input Shaft RPM, you can figure out what your efficiency is. Then mearly multiply your results from F-Body.org by that number for your true reading. I recently verified this with my B&M converter (which is 97% effiecient) and multiplied the results from that calculator and they matched my logged info.
12secSS is offline   Reply With Quote
Old 07-22-2005, 05:47 PM   #7
Pro Mouse's Avatar
Ok cool Thanks!!
Related Topics
Thread Thread Starter Forum Replies Last Post
Best Gear Ratio To go with c1o Gears & Axles 1 08-04-2015 12:31 AM
Clutch, Master or Slave? ADM Manual Transmission 0 01-05-2015 09:11 AM
rpm+gear = wrong speed? ben husen Automatic Transmission 12 10-30-2014 06:31 AM
Top Speed. Stone17 Cadillac CTS-V 2004-2007 (Gen I) 20 11-09-2010 08:41 PM
A4 won't shift into 3rd at WOT. Computer or Mechanical? mguidry629 LT1-LT4 Modifications 39 09-19-2010 10:11 PM
Tags
2001, 373, 97, a4, camaro, gear, gears, hptuners, ls1, ls1tech, mph, rpm, rpms, shift, stock, tables
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
