How do you guys rough in a VE table
I just start from scratch, log and make the changes like normal... Since no 2 cars are the same, I prefer not to copy someone elses VE table ... especially since it doesn't take long to get the table pretty well dialed in
Phil
depending how ridiculous the setup is. if you're tuning something truly ridiculous, you know you can cut like 30% off the first 3 columns, and start adding a nice chunk >4krpm. from that, just scan, adjust, repeat. starting off with something closer to your target just saves time, that's all.
Originally Posted by Bill Bowling
I am using a LC-1 WB and FlashScan's Autotune. It is really easy.
Bill
Bill
After Autotuning can you use the MAF again or do you have to run mafless with that tune?
You can go back on the MAF.
You will need a Wideband O2 to use their BEN Factor "AutoTune".
In fact, with EFILive's software, you can use a custom map in their scanner and copy /paste in a new MAF table - after you're satisfied with the new VE table.
They have really simplified the whole VE tuning process.
FWIW.
FWIW.
