why does everyone change the MAP PE enable higher with cam?
Old 07-30-2005, 10:53 PM
WS6FirebirdTA00's Avatar
Default why does everyone change the MAP PE enable higher with cam?
stock setting is 15 kpa, everyone says to put it to 70-75 with a bigger cam. why?
stock, pe will enable at the % throttle, you will never run under 15 kpa to disable it. so why would you want it any different with a bigger cam? or is it just somethng that would be even better with the stock cam to raise it, save gas?
i dont know but someone explain please
and what are those other settinsg on there for under map enable, in hp tuners
Old 07-30-2005, 10:56 PM
or is this to help tuning out?
Old 07-31-2005, 08:30 AM
to
the
top
Old 07-31-2005, 10:01 AM
JRick212's Avatar
yes please anyone I was also wondering about this
Old 07-31-2005, 10:22 AM
also everyone tunes the car in open loop with the olfa table, why not put pe enable settings all to 0 and do it from there?
i still dont understand raising pe enable map, unless its to hit more closed loop cells when tuning and then you set it back to stock.
Old 07-31-2005, 12:21 PM
WicketMike's Avatar
If your talking about the P0121 Parameters (min/max MAP)
Its becasue in the automatics, when you go WOT from a stop it will shift into 2nd gear right away, so i moved mine to 75/85
Old 07-31-2005, 12:27 PM
no im talking about the fuel control, power enrich tab, where it has the map, map hys, and mode delay
Old 07-31-2005, 02:58 PM
anyone?
Old 07-31-2005, 07:58 PM
so all the guys in here that change their map settings do it and dont know why?
Old 08-01-2005, 02:48 AM
02sierraz71_5.3's Avatar
I think all those conditions have to be met in order to fully enable pe rpms map etc..
Old 08-01-2005, 05:00 AM
only thing i come up with is so pe isnt always comming on, and that the stock setting is too low even for the stock cam.
Old 08-01-2005, 05:51 AM
Checkmate's Avatar
I never changed mine, didn't really see a need to because you still need to be above the PE enable tps % vs RPM.
Old 08-01-2005, 08:02 AM
i guess higher it is will keep you out of pe in some of the normal cruise cells, or heavier load. did you look at my tune i sen t you yet by any chance?
Old 08-01-2005, 10:27 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Changing this would just keep you out of PE longer...for me, I want mine to enable sooner, since more fuel under throttle is where the power is (but not the fuel economy).
Old 08-01-2005, 10:55 AM
im thinking it would be best for tuning the ve as well since you could tune up to whatever you set it to without worrying about pe
Old 08-01-2005, 12:50 PM
MeentSS02's Avatar
Well, PE should be disabled when you are tuning in Open Loop SD (which you should do for VE tuning, provided you have a wideband). I've been messing with my PE (on a stock cam), and I have it set so that it is WAY more responsive now. Granted, I'm running a closed loop SD tune full time, but I'll probably be posting my findings soon when I can get some more verification that what I did actually worked the way I wanted it to.
Old 08-01-2005, 12:58 PM
what settings did you change? im in SD closed loop as well
Old 08-01-2005, 01:12 PM
crainholio's Avatar
I'm only running a TR224 cam, and the data I collected showed no need to raise the MAP threshold for PE.
However, with bigger cams that make less vacuum (higher MAP reading) it's generally necessary to increase the MAP threshold value to keep PE from kicking in prematurely.
Old 08-01-2005, 01:20 PM
kicking in prematurely? this is what i posted for people say this but the stock setting is 15 kpa, the stock cam idles at 30 kpa, most of the cells i see when cruising are 20's so stock cam or big cam pe will enable the same if its set at 15 kpa.
what is your reason for it "kicking in prematurely" because i disagree with this and this is what everyone says. stock cam and my f13 both see above 15 kpa cruising, so the only setting turning on pe is throttle %, not the pe, since its always over that except on decel. raise the limit and get better fuel economy. lower it and get some more power on part throttle accel. put it up to tune ve easier. those are the 3 things i see with changing it, and thats it
Old 08-01-2005, 01:32 PM
HumpinSS's Avatar
15 kpa means it can be activated pretty much at anytime, setting it to 80 kpa guarantees it comes on when close to or at WOT.
Kicking it in prematurely will supress any knock that may arise from moderate to aggresive aceleration or loads on teh engine. I havent changed mine because i would like for it to come on as needed and if need be before 80kpa. I think people started doing this to kinda turn pe off for SD tuning. 80 kinda turn it off and would need a large throttle movement to hit this map value. When SD we arent trying to move the pedal that much so to speak. 80 still allowed the car to go into PE mode if you local mustang rolled up on you while tuning. This method to me is kinda redundant because we set this to 80 set the olfa table to 1.13 and turned off the pe table (which really isnt turning it off but anyways) and forced the PCM to use the OLFA table for ALL its fueling (PCM selects the richer of the two table values and that is why we set pe vs rpm to 1.0). with all that said I left mine stock (15 kpa) and my OLFA table and PE table both set to 1.13
Here is a description from the EFILive help notes
When the manifold absolute pressure (MAP) is above this value power enrichment mode can be enabled.
Quick Reply: why does everyone change the MAP PE enable higher with cam?
