Interesting - Speedo calibration
One of the first things I changed when I received my copy of EFI Live was the speedo. It was no wideband O2 SD tune, rather just a place to start. Anyway, I go to the right table and there was a sweet tire height & gear calculator that adjusted the right fields and all. So, I put in my new size (275/40/17) and it came back with 25.66". However, after a quick measurement the other day (after a discussion I had with a friend about real tire heights), I found that my 17's were only 25" high. Not a huge difference, but big enough when it's the difference between a 79 in a 70 vs. an 81 in a 70. No, there were no massive burnouts done on these tires and no I didn't get a ticket. My point in saying this is....don't always trust the calculators you come across. EFI Live is a wonderful product and I'm completely satisfied with it. But, there are just some things in the REAL world that calculators won't have the right answers for all of the time. So, keep an open mind when your tuning...and if there's something simple you can do (like measuring your tire height) to double check what your changing, check it and don't just assume the answer you have is golden. That's just my $.02 .
the only accurate way is by using the circumference...
not all tire manufactures follow *strict* standards...
I have had 3 different tires brands all say 275/40/17...but you can see a difference in the footprint it leaves...and all 3 measured a slightly different circumference
The circumference is not correct either, as it does not take into consideration the weight placed on the tire. You need to measure the tire height as it is used, hot and mounted. Take a trip around the block to heat up the tires (no, not burnouts ... just regular driving) then park the car and measure from the top of the tire to the ground. This is the most accurate way of determining the actual tire height. If you want to be ****, acceleration also plays a role in tire height, which is reduced. Be sure the tire is at the optimum pressure prior to making any measurements.
Note: I do not go this far to get the tire height, I an not that **** about the exact speed of the vehicle. If I was I would replace all the gauges with very accurate (expensive) gauges, which the OE are no where near, just good enough.
Originally Posted by WS6FirebirdTA00
good point. ill try this out on my car. i know from the factory the settings are lower than the calculator shows. how did you measure it? using the circumf.??
Originally Posted by SSpdDmon
No, Flame is right. You want to use tire height (diameter). At least that's how it's done in EFI Live. I just find it odd that it's off by over 1/2 inch. A tenth or two, I wouldn't care. But like I said, my friend and I were discussing tire heights and their effects on your final, final drive ratio (he uses 26" MT's, which is the equivalent of turning his 3.23's into 3.11's). Then I got side-tracked to whether or not my tires were the right height in my tune.
Restricted User
To clear up any mystery about how EFILive calculates tire diameter...it uses the following formula:
t = (r*25.4+(2*p/100*w))/25.4
where:
t = tire diameter in inches
r = rim size in inches
p = profile in %
w = width in millimeters
It does not attempt to take into account variations due to many of the reasons posted in the previous threads.
Regards
Paul
where:
p = profile in %
Regards
Paul
