what airflows for fans 1 and 2
recently when the fans come on i noticed a dip in rpms, i have been adding to the airflow for the fans since then to correct the intake trims. what kind of values do you guys have to put in for the airflow values for fan 1 and 2?
i believe the drop is due in part to the increases load on the altenator and the sudden increase in desired air flow. You could get a similar effect by turning your heater to all the way hot, then turning the fans on full blast.
