Tuning for a 200 shot??
I have been running a 150 shot and want to step it up. I have a 98 with stock internals and I have hptuners. I am about to order a fuel pump and was wondering what tuning I needed to do for this?
What do you plan to run for gas? Your going to want to hold the timing back to about 22 degrees if you want to try it on straight pump gas. If you plan to mix in some race gas you can up it to 24+ depending on the gas. Just make sure the car is getting plenty of fuel, I hold my A/F ratio at about 11.0-11.2.
Do you have a wideband in the car? If not get her back on the dyno and see what your A/F is when you spray it and if need be start swapping out jets until you get your desired A/F.
Matt
Matt
