can I flash a holden comodore bin to my camaro ss??
thats part of what I am trying to figure out...
which holden bin is the closest to f-body for compatibility..
I thouhgt my LC was working(because of MPG) but further investigation using my new wideband shows it is not...
I dont know what attributing to the good MPG..well...better.. It went from 23 to 26...
personally i wouldn't try it. There are many, many parameters that can potenitally be different that aren't supported by editing packages. Everything from what type of AC is fitted, cruise control, alternator diagnostics, instrument panel types and options, interfaces to traction control and many other vehicle accessories, the way the fans operate and are wired in, various diagnostics, emmissions tests, no rear O2's, EVAP system differences etc. Even more stuff to go wrong if it is an A4.
I flashed an fbody OS into my M6 monaro once and i got something like 40 DTC's, the fans stayed on high speed at all times and the cluster did some really weird christmas tree impressions Sure i could drive around the block, but it wasn't fun.
