fuel pump control
fuel pump control
i have a tank full of bad gas and am looking for a way to get rid of some of it without dropping the tank. my question is can i use the vcm controls>fuel & spark>fuel pump=on to switch the fuel pump on and use that as a way to get rid of some of the **** gas that i have without hurting the pump? i am thinking i can use my fuel pressure guages' bypass and take it straight to a fuel jug.
will this work?
will this work?
I did that w/ EFILive, disconnecting my return line (running an external regulator) and routing it to a fuel jug to pump out most of my tank's contents...worked like a champ.
thx. i wasn't sure, so last night i went ahead and started the truck let it idle and then bypassed the fuel pressure guage. didn't take long at all to get about 5gal out.
