problem with code p0336 98 corvette
replaced broken lifter after starting motor was missing on #2 & 3 code p0336 and then pcm quite and would not restart replaced crank sensor and pcm code and missing still there check wiring and grounds no miss or codes before replacing lifter also both coil packs have power going to them but no spark paks are good (please help)
